It was not wind blown. In fact that last part was insanely strong.Looks sketchy. Hope you were careful. Windblown trees are among the most dangerous, especially hung up like that. Lots of tension, compression, twisting, dynamic forces involved. Often unpredictable. I wouldn't do that stood on a ladder.
We did one the other day that came down on a footpath:
View attachment 262572 View attachment 262573 View attachment 262574
Just a bit!
How is it safer with a battery saw? I'd much rather have a powerful petrol saw for that. Faster acceleration, higher chain speed, more power. If you need to cut fast and get the hell out the way quickly i want sonething powerful with a small bar. (Hence 70cc pulling a 20".)
They are rare like a golden egg chickenI would've rather used my 50cc with 38cm bar, but only had that big saw with me. The extra handle on it helped too.
60cc with 40cm bar would be nice. We have a couple MS362s at work with 45cm bars.
Those clone kits seem popular, a generally get decent reviews. I'd rather find a nice used MS361 or Husky 365 Special though.
No all perfectly safe. Much safer with a battery saw. No for pro use though.
I can see by your cuts you have no formal training in dangerous tree removal. It’s a matter of time before your caught out. For your own well being don’t do it or go do the full chainsaw training. Not wanting to start a bun fight, only trying to save you some hurt
Lol yes you are partly correct. I am not trained in felling trees. I was qualified to chop up trees. (That had fallen down)I can see by your cuts you have no formal training in dangerous tree removal. It’s a matter of time before your caught out. For your own well being don’t do it or go do the full chainsaw training. Not wanting to start a bun fight, only trying to save you some hurt
Anyone spots anything I've missed please holler.
Lol yes you are partly correct. I am not trained in felling trees. I was qualified to chop up trees. (That had called down)
I have absolutely no doubts I am not a tree feller. I have however used a chain saw for many years before elf and safety was invented. For many years I worked in willow trees over a river once or twice a year.
Then a few years later I was driver on an emergency tender that had various bits of gear added monthly and they either made up courses or got people in. Things have moved on I totally agree but the quotes we had to get these trees chopped down meant it was a balance between safety and being safe.
I am intrigued as to exactly how it should have been tackled though.
No bun fight BTW I do respect the professionals.![]()
Not missed, but something to have a good look at: make sure there is absolutely no way whatsoever the concrete can get under the polystyrene or it will float*. So make sure the joins between the sheets are tight and cannot move laterally or longitudinally and separate. Make sure that there is no way that over-enthusiastic splashing of the grey stuff around the perimeter can get behind the insulation. Go easy with the poker/vibrator if you are using one.
* Look how well it floats on water, with a density of 1.0, so how much better will it float on something with a density of roughly 2.5?
It's is indeed a willow. My problem was getting access to use a face cut. So I chose to strap it to reduce the chances of it kicking back or upwards. And it's my understanding that this is a technique to prevent the splitting (I now know is called a barbers chair) But yes it did increase the chances of it splitting admit already had a pronounced lean.. Climbing was awkward and branches thin. But you will see when I take an after photo I did cut higher to reduce the height/weight/length from base.Without out doubt the safest would be to climb them and dismantle in small bits,
From the picture it looks like a willow, the danger you luckily didn't face would have been a barber chair, the stem splitting very dangerous situation.
Save yourself the headaches. Outsource it as I’m going to have to with some of these birds.I might have to buy myself a small cnc plama.
anyone wanna swap for a 3d printer?
I'll swap for my old one, it is smallish nowI might have to buy myself a small cnc plama.
Why?Save yourself the headaches. Outsource it as I’m going to have to with some of these birds.
Ah ok, just make them biggerNot a fine enough cut for the detail required.
Yeah I’ve made them a tad bigger, but they’re meant to be life size.Ah ok, just make them bigger
So laser required then?
