brightspark
- yarm stockton on tees
if u can drain and clean it without oil seepage belzona or devcon spread over it will work if left to dry and harden 24 hours
its been draining all day ill leave the sump plug out until i decide what to use, never heard of those 2 things beforeif u can drain and clean it without oil seepage belzona or devcon spread over it will work if left to dry 24 hours
its a better version of jb weld not as runny thoughits been draining all day ill leave the sump plug out until i decide what to use, never heard of those 2 things before
the 1111?if u can drain and clean it without oil seepage belzona or devcon spread over it will work if left to dry and harden 24 hours
is this the gear @brightspark https://www.zoro.co.uk/shop/materia...gm-inchainch-plastic-steel-putty/p/ZT1060906Xits a better version of jb weld not as runny though
yes expensive but good
not sure that would stand up to the oil and fuel and heatyou could use a PU adhesive like tiger seal or sickaflex 221 they stick car wings on with it does take 24 hours to cure though
thanks never tried it or JB weld come to that ill order some and give it a try.yes expensive but good
Yes with thorough degreasing, avoid detergents containing silicone, they tend to stop things sticking.if u can drain and clean it without oil seepage belzona or devcon spread over it will work if left to dry and harden 24 hours
Had similar issues on an old Corsa years ago but was lucky, the sump came off quite easily so was able to weld it up.
I was going to ask the same question but just beaten to the punch.shogun sport
A 1.9 diesel by any chance? see my note RonAI did my daughter's Corsa sump, took it off and gas welded it as it was too thin for mig. Coat of black paint and good as new. I would try draining that and heat the area and wire brush it then JB Weld to seal it.
