Brad93
- Essex, United Kingdom
Bison will be a pretty good quality collet chuck right? http://www.rotagriponline.com/index...ges.tpl&pop=0&option=com_virtuemart&Itemid=29
I tried to rein in the expletives hahaBrad, Just caught-up with this and enjoyed the video update - must be going well as no swearing. Going to be a well sorted machine and hopefully joyfull to use.
Yep I’m headed that way. Insert end mills will work out cheaper in the long run I’m sure. Still, nice to have HSS tools for softer metals.Tipped tools!
Wicked thanks, I just chuck random stuff on there, mostly new tools! Haven’t used the collet blocks yet but I’m quite happy with them for the money.I've subbed to your yt channel. After watching both you and John with your collect blocks, I have ordered a set myself![]()
Sorry I missed that, what's your YouTube channel called?Wicked thanks, I just chuck random stuff on there, mostly new tools! Haven’t used the collet blocks yet but I’m quite happy with them for the money.
First job for the square block will be to reduce the size of a nice chuck key I have that doesn’t fit any of my chucks. Second job will be a hex chuck key for the 4 jaw so I don’t have to use an Allen key.
Dry.Were you cutting that dry or with coolant. Feeds and speeds are very critical with hss tools on mills
Cast iron should be machined dry.Get the lube going, but you know that.
I love learning, fair point.Cast iron should be machined dry.
search chip load calculatorLooking on my mill, the speed closest is 416RPM and I do have a feed rate that will get me close, 0.008” per rev, which would be 3.25” per minute of travel. Little bit fast but probably wouldn’t have burnt the tip up.
