James1979
 - Orkney
To show off I suppose. I did wonder too.Wonder why they cut it with the piece vertical?
it wouldnt have had half as many hits that way ,,,Wonder why they cut it with the piece vertical?
he must have had no sense of smell and also left the shut off valves openWhat poses the greatest risk with acetylene is that it has the highest flammable range of any common fuel gas. LEL is just 2.5% and UEL 100%, that means it will explode at concentrations where other gases are either too rich or too lean to ignite.
Basically, don't keep it inside or next time you open the shed and turn the lights on it might turn your own lights out - permanently. This guy below had a bottle leak in his car, when he hit the window switch it blew all the bodywork off.
https://www.garagejournal.com/forum/showpost.php?p=1941027&postcount=55
 .one of my regs was leaking  just a bit   and I could smell it  instantly just nipped the bullnose up a bit and was ok. I allways purge my lines  and slacken  the regs  pressure   knobs  off when not in usehe must have had no sense of smell and also left the shut off valves open.one of my regs was leaking just a bit and I could smell it instantly just nipped the bullnose up a bit and was ok. I allways purge my lines and slacken the regs pressure knobs off when not in use
2 days later  smelt  the gas   in the pit
had to blow it out  with a fan started it up outside 1st  so no spark
lessons learnt from itOxygen cylinders can act like rockets if they fall over and the valve breaks. Just the shear pressure and mass of gasses suddenly escaping from the relatively narrow cylinder neck can propel it at dangerously high speeds about the place. And a full size O2 cylinder is pretty darn heavy !
Have you also felt any warmth further down the body of the torch? As @James1979 that flame could be because the nozzle/tip is not seating properly. I'd be inclined to take the nozzle off and check that it and the seat in the torch head are clean. Then refit, make sure the nut is tight (but no too much) and fire the torch up. If the problem recurs, I'd personally get shot of the torch.Having problems with small flame coming up behind the tip where that brass’s nut threads in. Not sure it cause I overheated the tip or not cheers
Or are harris ones better?Are boc sapphires good torches?
there great. I have one for saleAre boc sapphires good torches?
I have a butbro  set  as well    il never use
