zeppelin builder
- peoples republic of scotland
Progress yesterday finally welded the head up, the amount of contaminants was unbelievable. Had spent ages cleaning the head, grinding out the water ways and finally giving it a wipe over with acetone. Warmed it up for a good 40 minutes on the camping stove, set the r-tech to 190amps, 40% cleaning, 2.4mm tungsten and 2.4mm 4943 filler rod with 8lpm argon. Probably would have been better with a 3.2mm tungsten but the garage gremlins seem to have had them away, anymore cleaning action just melted to tungsten into a massive ball.
i used to weld up corrosion damage on bently heads , usaly use the first as a sacrificial pass ie weld it and dig it out back to clean , i welded up a friends austin seven head recently for dry decking , it was much modified with extra studs as it had a centric blower on it it had a seperate cooling system for head and block too
