PhillipM
RC race series trying to squeeze out every last horsepower - I think I did about 30-40 of them.
The stuff does get that lovely satin silky surface like you said though, I love it when it prints right:
Now you mention that very likely.Just read an interesting thing where the bloke is having the same issues with holes as my lad does. Could it simply be a bed levelling issue? Off to find my feeler gauges! He only ever levelled it with the "special" paper it came with.
https://3dprinting.stackexchange.co...em-printing-circles-holes-on-anycubic-i3-mega
Can you video the first layer going down..Just read an interesting thing where the bloke is having the same issues with holes as my lad does. Could it simply be a bed levelling issue? Off to find my feeler gauges! He only ever levelled it with the "special" paper it came with.
Maybe I should try PETG before totally writing off the Anycubic?
Its probably going to be happier at less than 0.2. Its a visual thing. I will see if I can find a video.Maybe...just started printing a test cube after I levelled it with feeler gauges to 0.2mm. As I say, before he used paper.
SKR Mini E3 is a great upgrade, I've got one in mine. Amazing how much of a difference the TMC2209's make reducing the noise of the printer. There's a decent guide here on changes required if you're compiling Marlin yourself: https://reddit.com/r/ender3/comments/hymv70/marlin_20x_guide_skr_mini_e3_v12_ender_3/Printer fixed and printing a polar bear for an automaton that the eldest daughter wanted.
I was going to add a bootloader to the existing main board so I could upgrade firmware easier but the stock main board is struggling memory wise. Ender left out a bootloader as they would have struggled with other features because of memory constraints. So I've ordered a replacement board based on a 32 bit Arm chip for the princely sum of 35 quid. Its the BIGTREETECH SKR MINI E3 V2.0 32Bit Control Board With TMC2209 UART For Ender 3. It's a direct replacement physically and cabling wise for the existing 8 bit mainboard. I'll probably have to compile the Marlin firmware but others have done it before so could probably download it, either way I don't mind.
Apart from a bootloader and no memory constraints it supposedly has better stepper motors drivers that are quieter which will be useful when I'm working and on a call. There's a bunch of other features but won't bore you with them now.
So I'll add the bed levelling sensor and octoprint raspberry pi after the board has arrived.
Cheers
Andy
I used one of these when I installed my silent board. Creality claim to have a bootloader in the latest board mine did not. LolPrinter fixed and printing a polar bear for an automaton that the eldest daughter wanted.
Cheers
Andy
found one that should highlight that he sets the bed BUT then dials it in...
I tried levelling at the 4 corners with feeler gauges. Got it pretty good but feel the gap gets less in between on the. X. Warped bed?
Interesting that video about bent rails on that chap's i3 Mega. If designing from scratch I'd want solid, machined rails and a solid as opposed to pressed metal deck for them to sit on.
Quite possibly. This is why a lot of people use a BL Touch. It actually compensates for warped beds.I tried levelling at the 4 corners with feeler gauges. Got it pretty good but feel the gap gets less in between on the. X. Warped bed?
I think that's why people go for a glass top. Me I'm just happy to be able to afford a decent functional machine built down to a price. I think my bed is "bent" but a mild warp (I haven't measured) doesn't appear to interfere with the performance. I do the corners, twice just using loose paper fit (probably a couple of inches in from each corner) then double check the middle which is also usually ok despite the perceived warp (which probably doesn't actually translate to the actual fibre surface).
As often as not though, I watch the first layer like a hawk and if that needs a tweak, I'll go round and tweak all adjusters by the same amount. There are so many variables, I'm still finding my feet to get consistent results. Chances are I've picked up "a good one" and have been lucky so far with the results. Then again, typically only people with problems seem to post them. When you're trying to filter out the vast online resources on this subject, you do seem to run into a lot of problems.
