slim_boy_fat
- Scottish Highlands
Something plastic and not cast iron.
I thought for a second you'd had a weak turn.
No lol....just getting in preparation for another monster load of cast iron.I thought for a second you'd had a weak turn.
There is a date plate on it. Its similar to one of these.The gear selector plate looks very modern.
Might coming via the EU rather than direct from China help?
View attachment 242820 A very stiff square and an angle gauge,just cruising e bay couldn’t resist,but then beats fiddling with lumps of rsj.
I've finally received the final part of my DRO from Banggood. It has come in three separate packages a few weeks apart. I never have much luck with Banggood. Stuff seems to end up out of stock or never leaves China. It is rarely a quick or trouble free purchase unless it is a small cheap item.
I went for this model as it appeared to be the same one that Myfordboy from Youtube uses and it seemed OK for him. It comes with covers and fittings. I've switched it on, plugged in a scale and it seems to work OK. Just need to fit it to my Marlow mill now.
The tracking on the last package to arrive (The long scale) shows it was shipped from China to Belgium and then onto the UK. Maybe that's why I've been lucky to avoid any official interference to any of the three packages along the way. Might coming via the EU rather than direct from China help?
Just arrived today, didn’t need it but that’s never got in the way of buying a new toy before. View attachment 242927
I'm about to order one of the Banggood DROs too. Did the scales come with any universal brackets etc?
Hi Eddy it takes 3” discs as far as I know seems like a 16mm bore so a 4.5” won’t fit without getting an adapter made. The discs that came with it look rubbish but I bought some 1mm ones for an air cutoff tool so I hope they will fit. Graham.What size discs does it take? 3"? or worn out 4.5" ones
What does it press?
