Wedg1e
They call me Mr. Bodge-angles
- Teesside, England
Both the DM8 and the DLM8 distributor setups are electronically identical. The DM8 uses a GM HEI module. The DLM8 uses the same electronics in a Lucas made module that hangs on the side of the dizzy. DM8 stator and pickup on the left; DLM8 setup on the right. The only difference is the amplifier connector. This GM HEI type setup is fitted to huge numbers of 4, 6 and 8 cylinder non-GM 80s & 90s cars, only disappearing when conventional distributors were replaced by crank triggering and coil packs.
I've seen a couple of RV8s (including my own) that had a strange 'rev limit' effect going on - seemed to pull hard enough but would hit about 5000rpm and just stop, then pick up when the revs fell. Turned out to be that pickup coil breaking down. On mine it eventually failed open-circuit and the car just wouldn't start.
For info, the coil should measure about 3000 Ohms or less; if it's substantially higher than that then it has to be suspect.
Also on the DLM8 with the ignition amp mounted to the side of the distributor: the amp is bolted to a small add-on casting that is finned on the back to allow heat to dissipate. The amp gets its earth through its mounting screws to the casting. If the casting corrodes two things happen: first the amp doesn't see a good enough earth and secondly the heat can't conduct through to the fins to allow the amp to cool. How this manifests is usually that the car runs OK for the first few miles and then starts stuttering (the amp is overheating).
Pull the amp and casting off the dissie, polish up the back of the amp, clean up the finned casting and refit with a bit (literally a smear) of heat transfer compound behind the amp and use new mounting screws and normal service should be resumed
A very unpleasant sound when one is sitting at the lights looking cool.
