You could do what I have done and position the reel outside the cabinet on the top and just drill a small hole to feed it through.
.@Onoff If you are putting an exhaust fan in then you want some gaps so air can be drawn in, a must if you are planning on printing ABS.
They are mainly for keeping the air temperature inside stable as sudden drops in temp from draughts etc can make warping and splitting along layers worse (ABS).
They also help keep the noise down.
I have seen the Lack table enclosures on youtube before it should be easy enough to size your perspex to leave no gaps although you might want to sit down when you price it up.
A large cardboard box would do in a pinch.
I have a single 120mm pc fan run off the the printer PSU, low down in one of the corners, no speed control just on full whack with a 4" aluminium flexi pipe to a board slotted into the top open window.
ABS being a petrochemical plastic gives off toxic fumes in small quantities so i would say yes its a must.
I don't print ABS but I use Steady tech ABS Pro .
Got one of those I think. Why low down? I was going to go up the top of the rear panel with a fan.
.But I do have a shield that prints round each part.
sorry mate you said "The enclosure is specifically so we can print ABS." I assumed you were trying pure ABS.Steadytech ABS Pro is what we're experimenting with as I've said.
Lad complained tonight of another filament snap using Steadytech PLA. That's the 3rd time with this batch!
Gave me an idea. We have an old and decent quality hifi cabinet that we have no use for and to good to scrap. With the shelf removed and door extended it may be perfect for a small 3d printer?
I have just seen this, I dont think the fridge would be allowed indoorsGave me an idea. We have an old and decent quality hifi cabinet that we have no use for and to good to scrap. With the shelf removed and door extended it may be perfect for a small 3d printer?
At a guess 500mm square deep and wide.
Just remember to consider things like access for reel changing, to the on/off switch, the memory card slot etc.
It was made by my grandad about 30 years ago who was a joiner. We dont have space and no 3d printer, so if its suitable and anyone interested Im offering it for free.
