Its not mine its my partner's. Shes been on the hunt for 4 years.
But i have acquired the the task of getting it running then restoring it.
This will include veneering the cabinet and tarting all the bits.
What is it?
A jukebox type thingy wotsit?What is it?
smell of hide glue. Lovely stuff
*It looks like an 42x1mm thread on one side, possibly for putting lenses backwards on M42 cameras for macro photography?
I'll hang on to it for now then, I'm the top bidder on a few vintage lenses so maybe I'll get to play with it. I figure I'll learn what I'm doing with everything manual (And more importantly, cheapYes you are right, they are known as reversing rings. Depending on the 50mm lens the images would be of reasonable quality once you found a way of holding in the pin that stops the lens down from maximum aperture. As you would expect there was an accessory for that too, known as a Z ring, operated by a double cable release.
Edit: The reversed lens could be used on extension tubes or a set of bellows for higher magnification.
) before I get anything posher.That is the way to do it, at schools or colleges they typically started off with Pentax K1000 you can't get any more manual than that.I'll hang on to it for now then, I'm the top bidder on a few vintage lenses so maybe I'll get to play with it. I figure I'll learn what I'm doing with everything manual (And more importantly, cheap) before I get anything posher.
), a couple of umbrella reflector things and a couple of heavy bags to keep it all in.
No I absolutely don't need it, I thought one might be handy and it ended up cheaper to get four.
40.5mm was a size commonly used in the 50s - there are still lots of old filter rings and adapters around. Now that some modern makers have resurrected the size, expect to see more of them.Oh, and none of them fit the silly little 40.5mm filter thread on my Sony kit lens.
A big pile of 2 mm and 1.2 mm aluminium sheets. All 125 × 125 mm square, cut from two sheets (one for each thickness) of 625 × 625 mm aluminium from The Metal Shop. Cutting them up was free (although I also ordered two uncut sheets of steel, so that might have helped: they usually only do 10 cuts for free).
I bought them as practice pieces for TIG welding. If I haven't got the hang of welding aluminium outside corner joints by the time I've got through that lot, I'll have taught myself so many bad habits I'll never master it!
Sounds really useful for practice piecesI've got literally thousands of bits like that on site. They have a U punched out of the middle but still got 3 straight sides.
I forgot to post this the other day, actually arrived before the camera. I was just browsing used photography stuff on eBay, found this, auction at 99p with £29 postage, I won it all for a pound and four pence! I couldn't believe he actually posted it, I know I wouldn't have.
View attachment 225440 View attachment 225441 View attachment 225442
Three big light stands, one slightly smaller one, a pole, presumably for a backdrop (I'm thinking green screen), a couple of umbrella reflector things and a couple of heavy bags to keep it all in.
It can be a tripod for now, until I find a proper one.![]()
