Screwdriver
So following on from the forklift truck débacle, I have been asked to install this:
Ok so there's a lot of empty space in it but it's 3.5 metres tall with a huge great motor to drive the fans.
This motor:
It needs 8kW or about 15 amps so I need to be sure about the wire rating because it needs to move about 2-3 feet from the isolator and socket. Also I need to replace a broken socket.
Not sure what this is bolted to it. Some sort of star-delta starter but with a built in timer (??).
I may try and track it down with the original company based on their sales record. Meanwhile does anyone know what it is?
I need to set up all of the machines in the room (about half a dozen) so that when you switch on any machine locally, it also fires up the extractor. There is probably a product out there that does it, it might even be built into each of the (Felder) machines but this is early days. I have said I'll have a crack at it and while it would be great if anyone might be able to help, this thread is also useful for me to keep a record.
This motor:
