mtt.tr
- Essex/Suffolk border
You need to stop telling me what I don't understand...
I thought I spelled it out above - flat head, spring loaded poppet valves instead of using the cam - sigh....
Has anyone tried this? The Americans used V8 engines, one bank running normally for power, the other purely as an air compressor, no fuel nor sparks, as a air supply for surface supplied air scuba diving
I'm sure there's lots of reasons why it's not done, but it's an interesting concept, well, to me at least.
I do not claim to know how scavenging works at a fluid dynamic level and the effect of swirl in what is effectively a shock wave but I do know it is critically important in the design of a cylinder head. The system is optimised to use that feature to both generate pressure and evacuate the cylinder. A makeshift compressor assumes the volume of air will simply be pushed out due to the displacement of the piston.
This is a commercially available kit, looks impressive for a small package 58CFM @ 100PSI !
serious kit, uses a redesigned cam
I had a similar one Dapph, bought from a show about 50 years ago, but it had an inlet valve on it so it drew fresh air into the cylinder through the plug hole. It used the vehicle cylinder as a compressor, it didn’t draw fuel/air mixture in from the manifold as it didn’t produce a vacuum. I don’t think it would work properly on an injection engine as it would continue to spray fuel, or upset the ECU. It worked really well, it was supplied with a small sort of airbrush spray gun. I think it could still be about somewhere, I’ll have to have a look.Way back in the stone age 51 yrs ago out in Germany I visited a Canadian barracks & popped into their forces shop at Zoest which was like an Aladdin's cave .
I purchased a nifty little device that you screwed in place of a spark plug , left the HT lead off and started the engine . On every compression stroke of the cylinder it was fitted to it pushed a small piston up to compress about 20 cc of clean air .
Good enough to inflate a car tyre in 4 min or so and good enough to operate a small spark plug grit blaster .
Both items came as a set with a small bag of grit IIRC .
Combustion chamber design is for improved combustion. Scavenging is to ensure that as much of the exhaust gas is expelled to maximise charge, and thus power. All we're doing is compressing air and expelling it. I think you are over-thinking the problem. Something I do a lot of![]()
It is a key issue because if you want to create a compressor, clearly you cannot allow the valve timing to overlap.
Hance my comment about removing the rockers and using another valve system.
Sounds too useful a purpose for a Harley POS. Boat anchor springs to mind.loadsa flow but little pressure......don't bother......ud be better off with a comp from Lidil......
did see a Harley 45engine converted.....again what a waste.....
Yeah that’s fine, glad to see you’re up to speed.
