gordon stephenson
- Skelton in Cleveland U.K.
Same as BS, ran my Pickhill 180amp from a 13A plug with no problems ever.
nooo just soldered a bit of 16 amp wire across the blown 13 amp fuse^^^^^ you haven't swapped it for a 6mm gutter bolt have you![]()
same on the compressor no discolouration or overheating on the pins in socket or the plugI agree with all of that, except for:I'm pretty sure its single phase not 3 phase.
No, you cant install a 16a fuse in a 13a plug.
Not least because I dont think you can get 16a fuses that size and if you could the socket would catch fire.
You can use the welder on a normal 13a plug with a 13a fuse. You might find the fuse blows if you turn the welder up to fill power.
If that happens you would need to have a blue socket installed for it and fit a blue plug to the welder.
Or just replace the fuse with another 13a one and turn the welder down a bit.
its a constant load so gets very hot . I find a welder not a constant load so diversity comes to play unless your welding continuouslyTo get you going just put a 13 amp plug on it for the moment - I reckon you would get pretty close to full power out of that, a 13 amp fuse will take more than 13 amps for a good period of time before it blows. To fit a 16 amp socket you would need to get your garage wiring checked out by an electrician to make sure it’s suitable - but I bet it will run fine from a standard plug.
thats a bi pricey for a plug !£99 for a bare plugThis rather special 13A plug will accept cable up to 16mm in diameter with 4mm2 cores:
https://www.analogueseduction.net/uk-mains-plugs/ms-hd-power-13a-uk-mains-plug.html
However, it is for the audiophile market, so priced accordingly !
for the same price in lidl you can get a plug with a length of wire and a welder hanging out of itThis rather special 13A plug will accept cable up to 16mm in diameter with 4mm2 cores:
As a rule, anything that requires 13A or less will come with a standard 3 pin moulded plug attached but if it needs a supply greater than 13A it won’t come with a plug.Assumed the welder came with a 16amp plug. My bad.
Remember the rubbish European 2 pin plugs are rated at 16amps so I am sure British ones will cope
https://www.euronetwork.co.uk/Rewir...EHKjkSjxkr3OQxmLZSw_byyEN7N5vDw0aAqyGEALw_wcB
save your dosh just put the 16mm cables in to an adaptable box and a bit of 2.5 flex in to the plug. does the same job and only about 3 quidThis rather special 13A plug will accept cable up to 16mm in diameter with 4mm2 cores:
mind u you wouldn't impress your geek mates if u didn't fit the overpriced plug anybody with an ounce of sense would just hard wire that size lead in and fuse accordingly. less connectionsOne of my welders has a Euro plug and a 13 amp conversion to UK plug,you just put the Euro plug in and snap it shut best of both worlds.
