The_Yellow_Ardvark
https://www.death-clock.org/
- Going Away.
He certainly does!
You are often on my way home then......
He certainly does!
I always use jubilee clips for that reason
I still have my Casio fx-39 from 1979 it seemed to cost a lot back then so i kept it for years and retired it to a box in the loft.
this is one
When normal times return and I venture back out again, it would be a pleasure to put the kettle on!You are often on my way home then......
Someone had to lower the tone.....
Nonsense, how is an ornithological reference lowering the tone.Someone had to lower the tone.....
Your just jellous he beat you to it aren't you?Nonsense, how is an ornithological reference lowering the tone.
I mean it must be obvious what he was referring to, seeing as he is a sea faring type (well a WAFI anyway) and the Booby is a Sea bird.
Not really, don't have a calculatorYour just jellous he beat you to it aren't you?
Just an update on the lawnmower. We have spark. I have my own special starter system. Managed to give myself a belt. Will be more careful in future.
Belts look fine and the cables work to engage drive and the blades . It's 24 years old. Been neglected but I don't think it has seen much work. No damage to the Nylon sprockets.
State of air filter.
The blades are the worst looking part. Will they clean up a bit in use? They hardly turned until I loosened them away from the metal plate that they cut against.
Carb float. It moves freely. There's a bit of clue showing to what's coming next.
Carb Bowl. Lots of lovely rust.
Had a lovely time taking it apart and having a poke around. I have ordered some new fuel hose, HT cap cover and spark plug.
Worth it despite being disowned by the wife getting called "Mr Trebus". Again!
Carb float. It moves freely. There's a bit of clue showing as to what's coming next.
Worth it despite being disowned by the wife and getting called "Mr Trebus". Again!
I think there is little danger of it starting while the plug is resting on the head..get the pull start working a better way of starting it
i only say that as me and my son was looking at a mini moto years ago and wanted to see if it would run before spending money on it i had the idea of a socket on a bar it worked well untill it started riping the socket off the bar and flying passed the side of my head if it would have been a inch the other way i would of had it right in the face and an alarming speed
