Ashley Burton
- Northamptonhire
@Wightsparks how do they compare? Is the non-automotive Pico good enough for your needs?
Ah, that's a shame, but good that Amazon takes it back anyway
Do you have access to a printer at all? I'm happy to stick the STL on thingiverse (or you could grab it from my onshape account) - will add link when I get back home.How much would the protector / bat holder cost me?
How much are the low amp probes?
What values can they test?
Issue is that the 3d printer is at work, and I don't pay consumables etc, so I can't sell the bits, obviously, and I also don't know if it'd be right to block access for other hobbyists at work to print bits for other people, if that makes sense.
For me, in terms of work compliance, it'd be much easier if someone else printed it - I don't mind if they make a few bobs out of it
An AC or DC clamp-on ammeter will just read the value of the current, in Amps. This clamp-on probe converts the current to a voltage, and the displays it on an oscilloscope. So rather than just a value in Amps, it can show the shape of a varying waveform, at up to 20 KHz, and it does this without having to cut or connect to the wire.Whats the benefit of that over a stand alone amp clamp meter?
Hi WrightsparksIt is (unofficially) possible to use the automotive software with it but not the waveform database.
Thanks I hadn't seen that one and it provides an ideal lock-down pastimeInteresting, I have not had any issues with the Hantek leads, but I'll watch out for it.
This is an interesting video on using the 2204 Pico for automotive work
You will also find the comments useful, especially replies to the second comment.
