Munkul
- Cumbria
The balance control on the aristotig shows a shallow puddle anticlockwise, and a deep puddle clockwise. This is your guide... you want it around 70% towards the deep puddle, this is %EN. Basically keep experimenting with turning it up until your weld beads turn slightly speckled, this is the point where you need a bit less %EN and more cleaning. It should be about 70% for most stuff.
You will be able to put a rough point on a 2.4 tungsten and it will ball back so far, but not as far as the end of the prep. This is with Lanthanated tungsten, correct?
Then, your 140 amps will definitely be able to do something on your 3mm ally
It's a nice set, it's a bit newer and fancier than mine was.
