doubleboost
- Newcastle upon Tyne England
I will post a link to my review later
The biggest problem is low voltage
What size workshop?So, for a complete novice to these gadgets - but I want one, can someone give me an idiots guide to which heater and PSU would be a good starting point to heat a workshop?
Jordandson,
Thanks
Also say thank you to your Father
PM sent
What size workshop?
What is ventilation like?
They are actually 4kw - not the 5kw or 8kw claimed. Still brilliant and great value though!ive got a 5kw in a garage double the size of that. a 800w pc psu hung off the side of it. works fine, gets it warm enough to work, no psu issues.
well yes, and no.For a garage I would use one of these unless you are paint spraying or something - it has a naked flame inside.
thank you and your father it’s very generous and kindAll posted Sammy you should get it tomorrow or Saturday at the latest. Father said while your waiting for it to arrive grab yourself a 12mm box spanner and make a 4mm wide cut down the side 30mm long
else you will have the same problem getting the glow plug in if its the same setup as the eberspatcher ones. Tool station do a hole set for less than a tenner.
Oh and the little black thing
also in the package is for removing the mesh screen should your have it in your and need to remove it to clean it. Father has a few spare ones so he said chuck it in.Fathers in a good mood today
The links I posted are a different kind of heater!well yes, and no.
the naked flame is in a sealed burn chamber which is vented outside. the heated air is passed over the burn chamber, it works like a fan assisted central heating radiator.
there is zero chance of it igniting spray mist. there's just no way the mist can get at the flame.
in-fact i once deliberately sprayed a spray gun straight at a gas heater(so straight at a naked flame) , it didn't ignite...
