Memmeddu
- Italia Sardegna
View media item 10599Ok we can play
What's that?
What's that?
OOPS!! did that to a 12mm one a few years back, was kicking myselfToday I made - A Mistake.
Quite an expensive one, was my favourite boring bar too. 18mm, through coolant, anti-vibration :-(
Looking for a replacement but looking on banggood as I just cannot stretch to £200+ Can't find any though, do Banggood do Carbide boring bars?
Thought it looked a reasonable size. I think I have only ever seen up to 12mm from the Chinese sellers.
Made this thing today because I was thinking to repair the ladder step but I couldn't because logistics (my mother washed a lot of t-shirts ,and the ladder requires a lot of grinding )
So I couldn't kill my welding desire today and I figured out to make this useful tool
Used two pieces of flat stock (20x8mm) from the scrap bin
Chamfered both sides leaving 1mm landing
Welded using 2.5mm 7018 just because I like to run LH rods and I didn't use them since a month or two cos everything I welded in this period of time required using 6013
Set my inverter around 100A and to be honest it was little bit hot but I am to lazy to dial the welder 5 or 10A less
So I left little bit of undercut but I think that it's also because my manipulation
So now it's your task to understand what I made just for Jocking little bit since today is Saturday and I am the only guy in this world that doesn't go to the disco![]()
Ceilings a bit low. Mind your head....
Made a quick plate to cover the hole as a temporary solution
Vmax liners are 82.93 od, 76mm id
Quick question to the knowledgable, these liners are pressed in, how hot should I make the block? Planning to use my ceramic plate to warm it up, put liners in the freezers, and bang em in.
Buy the LED tube replacement and keep the light ?I made the garage a bit brighter, and also now have light over the workbench. Now have an old 6ft single strip light tovget rid of.
