Madforwelding45
- Tipperary
Ac stick welding has its uses it eliminates arc blow when when welding into corners and on magnetized . Plus the oil cooled plants are probably built to last
The main reason would be there is very little to go wrong with one,Why would anyone want one still? They're dinosaurs. If you're desperate for a transformer based welder, then they still exist, but usually 300 amps + for heavy industry.
The likes of Pickhill bantam are AC only, which limits your rod selection. So for professional use, they're more likely to spec a DC or an AC/DC set.
Up to 4mm rods, why wouldn't you want a DC inverter? Unless you were super tight on budget...
I refrained from saying such, but you are 100% right, and these welders are still usedAc stick welding has its uses it eliminates arc blow when when welding into corners and on magnetized . Plus the oil cooled plants are probably built to last
I’ve encountered such, this is why I like the old AC oil cooled, you alwaysArc blow can be so annoying on certain steel . Where you have cattle scratching again feed rails ect the steel becomes magnetized and causes arc blow and can cause problems when repairing them with a DC welder
I will be keeping mine, even though I’ve been told such items are dinosaurs.The ac stick plant will always have a place I think anway
we got rid of ours simply because it had no place left on the farm for us - we don't have great issues with arc blow anywhere, and we use a lot of 7018 which prefers DC current.I would agree, for certain rods a modern inverter that can handle 6010 and 7018 wellNah, that's fine, I get itwe got rid of ours simply because it had no place left on the farm for us - we don't have great issues with arc blow anywhere, and we use a lot of 7018 which prefers DC current.
IF you haven't used a modern inverter (a decent quality one, anyways) then TRY one!
The first Mig I bought was so heavy compared to other makes I looked at,because they last forever, probably
Not many stick sets (and only stick sets) sold for professional use these days.......the most common would be portable or running from a genny.......so they pick inverters because they are light.........The first inverter made by Lincoln had bricks in the bottom to make it heavier...they were afraid of theft because they could be lifted by one man
Some of them got a hard time, ours is still going after 50 years,I understand the reasoning... but they actually don't.
Water in the oil
Corroded base leaks
insulation break down around terminals
weakened spring contacts internally
All faults that can and do happen with these transformers... Yes they're generally fixable, but it's a horrid experience and involves possibly carcinogenic transformer oil.
We scrapped two of them in my memory - one for leaking, one for insulation breakdown. The leaking one was fixed once or twice, but I was just a boy at the time.
The third one, the one we sold, actually had an annoying fault where it would sometimes just run cold welds. We never bothered to work out what the problem was, just chucked it in an auction since it did work still.
That's my experience. Of course, I learned to stick weld using one of these oilcooleds when it had insulation breakdown, and therefore buzzed you from the return lead with a shock. I hated it with a passion, maybe something to do with how much I still hate them![]()
Water in the oil
Corroded base leaks
We scrapped two of them in my memory - one for leaking, one for insulation breakdown. The leaking one was fixed once or twice for another fault, but I was just a boy at the time.
Our Pickhill came from a ship yard on the Clyde, as probably did nearlyYou must have had the one.......Ive known them be 20 years old still original oil still running like a good un.......Shipyards used to have what was known as Pots......similar thing but 4 welders running from the same pot........the only reason they had to change is they couldnt calibrate them.....indestructable they were.......same in the MoD factories making Challenger Tanks, burning 10mm Stainless Rods all day...no-one knew the current just the settings but you had to knock it up a notch when another guy struck up.
We used to use one for testing rods. The reason being was thats all we had at one time but when the technology improved we knew if it ran on the Pot it ran on anything....we had to introduce big wall mounted ammeters.
On the other hand the first Inverters wouldnt last long at all. Lincoln couldnt apply their famous 3 year warranty to Inverters....obviously they got better.
I'd say we probably got machines right at the end of their life, to be honest... Dad and uncles were and are still great for buying junk and expecting it to do another lifetime
All 3 machines had those metal wheeled carriages.
I was SOO happy the day they decided to scrap the shocky one... then they dragged another big old machine into its place!![]()
....fortunately it never happened to me
.....maybe because Im old
