good job you take it light heartedly@Parm Fun and funds. Plus a tomorrow, thanks to a good man.
@brightspark It is rubbish to some.
But were 's there muck lad, there's brass.
send them to meDoes two 6ft LED replacement tubes count?
I'm still trying to figure out how to fit them in a 5ft fitting though
(note to self - measure, don't guess!)
good job you take it light heartedly![]()
Unless the old fittings grow and have the correct guts to run LEDS.
The acquirement means NO does not count.
Unless it counts as experience.
A classic case, it is my ball and I am going home.
You’re only up the road from me!Bought this from Blackburn services last night (for consumption on saturday night...) purely on the strength of the label:
But having been sat in a field overlooking Darwen since 8 o'clock this morning waiting for a lift supervisor so I can drop the left hand of these 2:
...it might not last that long. I'm the only slinger onsite but I'm not a climber, and all the riggers are climbers but not slingers, so we seem to be at an impasse... Yet another night parked on the moors surrounded by sheep seems likely
I am not sure it would solve your problem even if it worked.They came with bypass starters, so work fine in older non-electronic fittings.
One has been used, but not where it'll solve my flickering light above the lathe problem![]()
Don't fancy parting with one of those do you.
@Parm and @eLuSiVeMiTe the plan as soon as a i spotted the 3 meter lengths was to remove a few of the rollers in the middle and drop a chop saw in it and at the moment i only own a few of them but if the guy wants to leave them with me for an extended period they may come up for grabs.
Cool@Parm and @eLuSiVeMiTe the plan as soon as a i spotted the 3 meter lengths was to remove a few of the rollers in the middle and drop a chop saw in it and at the moment i only own a few of them but if the guy wants to leave them with me for an extended period they may come up for grabs.
Got loads of room.Good stuff.
I don’t need a chop saw stand, or should I say I want one but no where to store it
Seriously I couldn't not make use of that. Your lathe and mill would go great in there.Got loads of room.
Get rid of the bar lol. Make a great workshop.
I will be going to collect other stuff on Monday and i am sure he had other sections which had been bent up so maybe i can cut the bottom section just to save the rollers.Cool
I'd only want two lots of 4 rollers lopped off tbh.
Would mount them on top of these.
Then can use for chop saw table saw thicknesser etc as height adjustable.
I'm always on site so makes sense for me.
Be appreciated if you can.I will be going to collect other stuff on Monday and i am sure he had other sections which had been bent up so maybe i can cut the bottom section just to save the rollers.
