Tinbasherdan
Bodger in chief
- Bolton, England
Ahh, number one problem for me is my battery box is full of batteriesmight end up going in the drivers side toolbox then. Do you find you don’t need to use the factory asthmatic fan to clear the screen? Mines about goosed so I’m considering just doing away with it completely
What are you planning on putting it in - 110 or 90? Can't remember what your 6BT build is (assuming it's that).id duct it away from my legs if I went that way. Cubby box is a no due to needing to be able to remove it for dog related reasons!
I could put it on the bulkhead in place of the std blow, but I’d like to keep it in th cab, bit more waterproofWhat are you planning on putting it in - 110 or 90? Can't remember what your 6BT build is (assuming it's that).
If 110 there's plenty of options under the rear tub, there's quite a nice big space behind the rear wheels that you could easily fold up a box to go in there to house it. I've got a P38 air tank (10l if I remember correctly) tucked up behind there to run the two Ashlockers and various other stuff (good source of air for the plasma ironically because the pump is so powerful).
There's actually a fair bit of space above a standard LT230 below the centre seat / cubby box floor. Probably just enough space to fit a diesel heater (the front has a few inches of clearance if I remember correctly.
I used tin inserts in my Volvo 240GLT, it was designed to run on 5 star, didn’t need the leaded part though. If I ran it on unleaded, it pinked very badly, put tin inserts in & it ran great, 260k until the body fell to bits. I know they are regarded like snake oil by a lot of people, but it really did work, the engineering adviser to the Civil Service Motoring Association (CSMA) ran long term tests for many thousands of miles to prove them.
I too had both cartridges on my car & my daughters car on a nylon retrieval cord .David Locke, that’s sounds right, I had a long chat to him at the time. From what I recall the tin pellets have to be in contact with steel to work, that’s why they are in a metal gauze sock as so many tanks were coated on the inside & plastic was starting to be used. I asked how it worked & no-one really understood, but no-one would put up the money to investigate it properly. I had it on a string in the Volvo so I could remove it if it didn’t work or move it to another vehicle, that was David Locke’s suggestion.
Edit
I had similar with the plugs, they did about 100 thousand, still looked new, at service time took them out, looked & put them back in. No electrode erosion at all.
Problem we are having is the battery box is missing from Winchboys Land Rover, its just got a really poor wooden oneThe wiring goes back to the second battery now so it's not such a birds nest now![]()
There used to be some catalyst pellets used so you can run a old leaded fuel engine on non leaded fuel . They work well as They align molecules in the fuel which results in a much cleaner burn .
