Sparkyarc19
- London england
Ok I'll update soon
Wo mate this is not convo for that kind of talk no need to be arrogant right I'm not a pleb I understand how dead you can make your self from touching the pretty tame wires with the pretty copper colour clown if your not giving advice basically go awayHow to set fire or not set fire to your caravan in simple steps.
step 1... try and fix the dodgy electrics yourself... or
step 2 spend no more than an hours labour using an electrician to rewire your fuseboard safely and correctly, avoiding steps 3 and 4 .
Step 3 if your caravan goes up in a large plume of nuclear type smoke, you loose everything, your excess, and possibly your life in a burning caravan.
Step 4 , refer to the co op for decent deal on cremation prior to starting step 1,which you probably wont need as youd be burnt to death in your sleep anyways, but the undertaker will have to come along and sift through the ashes, to put all your bits in an Urn.and charge your estate about a grand for his services.
Dont be fooled by the pretty looking little tame wires with the lovely copper colour wires.
Look at the energy, sparks,and heat ,you can make using a welder at 200amps fed from 240 volts.Its Lethal. If you dont know what youre doing, dont mess with it.Simple.
As wired in the supplied images the feed appears to be correct polarity.I have read the thread, it looks to me like the feed has been wired up backwards, so the live is going down the neutral side, so your neutrals are lives and vice versa, which would also mean the neutrals going into your appliances go thru the fuses in the plugs and the lives are unfused through the neutral path. This is big stuff. dangerous as feck.
