hotponyshoes
- Somerset. Uk
Some of them do.
Item number 7 232 31 00 23 9 from Fein. It handles 5mm, has a 1200W motor, costs a mere £2,631.
A slightly more realistic offering from Bosch is the GNA 3-5. It has a 620W motor, weighs 3.5Kg, costs £780, but only goes up to 3.5mm.
These numbers make the mentioned EN4 nibbler from Stakesys sound like a real bargain. With a 625W motor the claimed 4mm cutting capacity is a little doubtful, but with a weight of 4.6Kg and that hefty-looking nosepiece it might be possible.
That bosch thing will go through 3mm corten steel without issue. I would be pretty sure it would do 4mm no problem. Depends how tight some of the curves are as it has nothing like the small radius of the smaller nibblers
I bought the bigger version of that metal cutting circular saw blade to rip down 6mm sheets, aside of the shower of hot metal snurgs the noise is incredible, laying the steel sheet on ply when cutting does help but still noisy.
