God mode restorations
- uk colchester
I was supposed to start the ground work this weekend but the rain put a block on that.I wanna visit the museum too!
You mean you didn't get one for the workshop too.I received some nice plumbing kit!
This manifold and another the same for the opposite side is going to be for the downstairs heating in the house when I get round to fitting it all!
It's getting cold now so I have to pull my finger out!
Well I'm thinking of running a pair of pipes out to the workshop if it ever gets built! The exisiting garage is not insulated so not worth heating.You mean you didn't get one for the workshop too.
European style plumbing? I'm Assuming that's what I'm doing. Wall hung radiators run with soft copper coil under the wooden floors, no joints to fail. Yes expensive but so is ripping up solid oak flooring if a soldered joint springs a leak! Also we are out in the woods so do get mice etc and I didn't want to risk using plastic pipe as they do eat it! and of course all those push fit joints!!!
Something like me that I'm working open air until I will have a workshopWell I'm thinking of running a pair of pipes out to the workshop if it ever gets built! The exisiting garage is not insulated so not worth heating.
I've got one of these. https://www.machinemart.co.uk/p/clarke-cew1000-electric-impact-wrench/
420nm apparently!
I think its a load of rubbish. Wouldn't take the wheel nuts off my old Ford Focus. I understand that wheel nuts are a funny thing and they can corrode onto to the threads but this was mains powered. Now I've had the use of an impact wrench I found I don't like them. It's the lack of mechanical sympathy employed. I would use them on old exhaust bolts that are getting binned but not on anything that remains on the car.
I haveHave you got the SIP jig borer to sit it on yet?
I have
Spencer is without doubt the most crazed tool hoarder Ive ever met.
He doesn’t even need to know what a machine or bit of tooling is to sell his soul to buy it!
Hes shot to pieces.You say that, like it is a bad thing.
I bought a cheap set containing a drill & 1/2" impact driver years ago. The driver doesn't have the torque to remove wheel nuts but if you crack them first with a bar it will spin them off. Likewise it tightens them just enough to finish with a torque wrench.
It will handle up to M8 bolts very well & just about torques M10 fully. Great when stripping an engine or for removing a sump pan.
