123hotchef
- Kent
how do they work?
how do they work?
oh and it is a blind hole 35mm deepDrill out round. Broach to square.
Or get busy with a file.
I have an old scroll saw which can be doubled up as a die filer
i could drill the hole deeper yes sure. Can I not just use a thin milling cutter and take the corners off
what is a wobble broach? https://www.ebay.co.uk/itm/Broachin...233022929623?_trksid=p2385738.m4383.l4275.c10
Was that what you were trying when you snapped that milling cutter previously? What diameter of cutter would you end up using? As long as the cutter you have has sufficient length on the flutes you probably could. but the 'slot' will always be rounded on the corners, of course.
Seen them used in a lathe tailstock when forming hex holes in fixings.
Creates a wobble. Much like wiggling a drill with a blunt holesaw to rotate what corner the broach cuts onhow do the work though? looks like both bits spin?
Mines a through hole. No reason it needs to be blindNo I was milling down large T nut the cutter snapped because it came loose due to me not having a spanner to tighten the arbour. I would use the thinnest cutter I have I guess 4 or 6mm, a slight rounding in the corners should be ok I am making a handle for the machine vice
Mines original if you want picsno it does not need to be blind at all. I can easily make it a through hole then square it off
Need to go turn the vfd off anyway. Will post here.yes please mate no great rush my bed is calling.
