No good for slap heads.....
Same over here, even in the city centre, its gone to hell in a handcart. Banks, tattoo parlours, fast food joints (don't mind a good fish and chip shop though), charity shops, and endless cafes and coffee shops. Loads of high falutin' shopping centres which the wimmens adore, but i hate with a passion, there is nothing in these places for men, no tool shops or the like.
Everything I need is in there.Collected today.
Big heavy lump and very well made.
No use to me in it's current form
Will open it up and have a proper look soon and see if any options present themselves.
Worst case it's 15 quid so won't lose any sleep.
If I had one of these I certainly wouldn't be swapping it for a Colchester.Nearly as useful as the one on my Colchester![]()
Speaking to Chris at bracehand while I collected.
All there lathes are a pleasure to look at.Wow!
To day I acquired extra heat in my mancave also acquired the knowledge that B&Q orange plastic buckets are very flammable . Next door but one has been having a day long smouldering bonfire , god knows what he's been burning but it ain't just wood .
I did couple of vertical MIG welds each about 25 mm long didn't realise the blob had dropped into a B&Q bucket filled with bits of Delrin off cuts . Turned the welder off to let it run through it's cooling cycle , turned the CO2 off , swept the floor , wife called me in to answer some questions . Decided it's not worth going back our again as it was time to come in for tea . I was about to close the garage door using the remote fob . Just happened to walk down the hall to see that it was still open and noticed 2 foot flames lapping up the argon cylinder & under the welding bench .. hobbled out as quick as I could , put the spray rose on the hosepipe & played Fireman Sam ( with an Yorkshire accent ) for a few minutes, mad sure the argon cylinder was cold . Then used a spade to shovel the mess out side and ensure it's totally stone cold .
It was then that I realised hardly any of the orange B&Q bucket was left , there were still lots of very thin strips of Delrin that had hardly bubbles up , one or two 15 mm thick bits that were well melted .
Ok obvious mistake the bucket should not have been near the welding bench , not so obvious ….. the flammability of the orange bucket . Others bonfire smoke can dull you into a sense of false security when you're welding or grinding .
Lesson learnt , I live to fight another day . Now off to give it it's final check an hour after the event . Then start cleaning things up .
Lol.I've had five 1024s and they all leaked oil terribly. To change the centre seals on either side of the belt needed a full headstock strip. Its not a b for the faint hearted. It will take a full two days to complete. The design had some faults. I would not recommend them to anyone I liked,
If I wanted it to make money yes.@eLuSiVeMiTe
Get a Holbrook C10 or 13.
