dobbslc
- Hertfordshire UK
Yota.looks strong,what breed is it?
That’s a hell of a deal.8x4 welding table with a inch thick solid top and a 6 inch vice with it
For less than scrap price!
Getting it on and off on my own was errrm risky as it weights i recon nest part of a ton
Not sure about the truck but Toyota and Yamaha have exchanged technology in the past, I'm pretty sure Yamaha did the cylinder heads for their F1 car years ago. 5 valves per cylinder???? crossbreed between toyota and yamaha
It's a Toyota Land Cruiser 70 series, 4.5L V8 turbo diesel
What more do you want to know, its blood type and inseam?Come on more info
It's 205BHP, 430Nm torque from 1200rpm to 3200rpm in standard trimCome on more info
You is teasing me!I forgot to say it has a side exit exhaust too!!
No not calibrated, not designed to be. These are just to illustrate size and scale. Only work if the photo is taken 90 degrees to the viewing plane.
Anything that needs to be measured has to be done with calibrated technical equipment.
The circle should appear as a circle in the pic. If photo is taken from an angle the circle will appear as an eclipse, therefore the ruler cannot be used
That looks seriously understated.
Here is one more, I'm actually working away right now so I havent even seen the truck since I got it, and wont get to play with it for another 12 days!You is teasing me!
Come on, we need more photos!
As they say in football commentaries "The boy done good".
I rang my steel supplier for a price on an inch thick sheet a few weeks ago and had a small heart attack.
