Parm
Respect The Sound System
- Towcester
I was asking about the ignore button on another thread, never used it though, hope I've not upset anyone![]()
Dunno what your saying, can’t see any of your posts
Normally such ducting should all be metal based and earthed out . Should anything happen untoward and a claim is in the offing the insurers will go to town big time to prove it was your fault .
You might need to think of a hose with a fixed bare copper grounding wire running through itand the same within the pipe work ie all joints connected with a earthing strip so you don't get a near fatal static electricity build up and /or an explosive discharge / ignition in the pipes & outside when there is the right amount of dust to air ratio. It happened in the carpentry unit adjacent to our plant hire business ..the explosion & fire took out several other units in the same block as well .
See" explosion at the flour mill " for an example of what a static or spark dust explosion can do.
This govern publication tells of wood dust fires in air extraction equipment
http://www.hse.gov.uk/pubns/wis23.pdf
Also oil free so perfect for dentists who don't want their patients complaining that they got a gob full of Duckhams
It could mean there is a tube down to the bottom of the tank but more likely simply drain the air here .Interesting it appears to have a drain valve on the top of the tank![]()
even came with a few free gallons of water in the tank![]()
...... Heavy!Couple more grinders for the collection. The lower end of the Bosch Professional scale but very nicely made none the less. Nice slim design too which is good for my small hands.
Think we need to agree to calling them whizzers …
Grinder's makes the hair stand up on the back of my neck
To be fair, they do sound pretty angry.My daughter calls them angry grinders!
I didn't realise Men In Sheds had Women, I thought they had the WI, or do you need to be fully inclusive these days?But I will get a MIS member who has very poor eyesight to do it, under supervision. Why ask her to do a small one when she can't see it.
It's open to all men .
It's just that the women seem to have more wo (e) according to some dinosaurs
