The forks are original the only thing that been changed is the rear brake.
This one’s and Alp which would have had V brakes originally. My one way back when was an X-Alp with Magura hydraulic brakes front and rear.
You missing the other two?You missing the other 13?![]()
Pardon my ignorance both, but are these rare/hard to find?![]()
Mike , are you going to chop the power points in whilst it's empty ?
What are you going to put to the rear of the stove to stop it burning the wooden skirting boards ? I ask because if it is anything like our old multi fuel burner it will get very hot indeed especially when there is a good blow on outside and the air pressure inside the house rises & drops across the top of the chimney causing the fire to draw like mad .
Weird to say I acquired, just found him in the sink really and wanted to share, I'm sure there's someone here doesn't like them.
I resisted the urge to fling it at my brother.![]()
How about seeing if you can use the thin end ball point pen refill springs , such as a shaped Parker pen refill spring ( there are others around that are much cheaper) snipped down comes to mind ? They are a lot less in diameter spring than a standard refill that has wings on the sides .
You've made me get mine out now, not ridden in months.After scrolling aimlessly through facebook marketplace while watching tv I found an early 2000s Monty trails bike.
It’s very similar to one I had back then and didn’t cost much more than a couple pints and a pie.
As I'm Sharing bikes.View attachment 191237
Found a pic.
Both now gone unfortunately. Will buy another when I have time to use it.
That's an 01 I also owned an 02 on Jersey.I had a Mont like that! Lovely bike, but bit of a handful for and oldie like me so I stick to Twinshock now
You don't think he's cute then? Just scampering around like two puppies.![]()
A new garden shed. Not as good as it sounds as it used to be my transport. I've narrowed the problem down to the injector pump, which I can neither fix, nor afford to get fixed or replace. Best go and fins something useful to do before I burn out the swear filter.
