if you're using something that going to get warm you may need to look at a specialist adhesive as most superglues arn't recomended to go above 100C. the last superglue I bought was loctite 454 as it is supposed to be able to work up to 120C. that failed at a temperature of less that 110c and was for gluing wooden cladding onto a model steam boiler. the epoxy resin that can be used upto 150C worked better.
Loctite 454 data sheet below
https://tdsna.henkel.com/NA/UT/HNAU...C0959882571870000D797/$File/454-212NEW-EN.pdf
, super-glued to his forehead. In light of this being a family friendly forum I won't go into any more detail, but it seemed to be stuck pretty well, so if anyone knows the brand (of the glue) It'd be a good recommendation.
