Hood
- Carnoustie, Scotland
@Craig-SM mentioned about the grease gun he got the last day and said it was good. I have never been able to get any of the grease guns I had to work properly, they would work for 3 or 4 squirts then you would have to bleed it and the cycle repeated.
I used to have an old style one that was my dads that you filled with grease and it was great but inconvenient, I always regretted giving it away.
Ok so enough blethering, I order the grease gun last night and it arrived an hour ago so I put a cartridge in it and a few pumps and it was squirting grease 3m or more
Tried it on the profile rail trucks on the plasma and unbelievable, worked exactly as it should and I greased all 8 trucks and not an issue, never had to bleed it once. I have been on a greasing spree and have used at least half a cartridge up already and it is brilliant, amazing how such simple things give pleasure to simple people
The only downside so far is the strength needed to get the gun off the nipple, I pulled out a couple on the trucks as they are only screwed into the plastic ends but I found that wiggling it in a circular motion as I pulled it off helped and it does seem to be getting easier so maybe it will free off a bit.
Anyway grease gun here.
I also got a 1/4" socket set from Halfords and it seems nice although I haven't used it much yet.
