123hotchef
 - Kent
Can pick up a 2hp 3 phase motor for just over a ton. VFD from 60 upwards. Controls you can build yourself.
that is not too bad,
would I still need to factor in a phase converter too?
Does it come with an idiots guide to connecting it all up!What you need is this set up. Just got mine today. View attachment 179266
I hope soDoes it come with an idiots guide to connecting it all up!
Everything's marked. Hardest part will be scouring the manual to find the pendant connections and relevant settings.
Even the motor should have schematics for swapping the jumpers to delta.
Yes. Everything is marked and labelled.Does it come with an idiots guide to connecting it all up!
Did it come as a kit, or did you order different bits?Yes. Everything is marked and labelled.
As a whole kit. AC/DC drives .Did it come as a kit, or did you order different bits?
Plenty of options available.
Fly lead length.
Motor poles.
Foot mount. Flange mounts. The usual stuff.
ACDC drives.where did you purchase that kit from spencer?
