If you’re owt like me, you miss being able to point at things with the pipe in an old timey fashionThere is one thing that I really take bad with and miss greatly now that I don't smoke the pipe and have taken up vaping, anyone guess?.
Nope, can still do that as it is a vape pipeIf you’re owt like me, you miss being able to point at things with the pipe in an old timey fashion
No idea but I really miss skinning up/rolling.There is one thing that I really take bad with and miss greatly now that I don't smoke the pipe and have taken up vaping, anyone guess?.
No interest in smoking anything again but there was something satisfying about rolling.
Cut a few angles, 7 and 4 degrees, not quite finished. Needs 7.5mm holes for the rope.
The original ones were simply nuts with the thread taken out and para cord tied in a loopIt’s known as a nut
And the really small ones might slow you down but they sure as hell aren’t stopping youThe original ones were simply nuts with the thread taken out and para cord tied in a loop
i have seen a few pop out in my time lolAnd the really small ones might slow you down but they sure as hell aren’t stopping you![]()
Did a route in the lakes, and there was a couple setting up to follow after, by the time we walked off the guy had got 3/4 of the way up, bailed and his gear had unzipped top to bottom. Air ambulance jobi have seen a few pop out in my time lol
Pulley for the "new" motor on the rapidor, aluminium, 77mm o/d, machined the groove with the compound and my parting tool and my battery gun. 3/16 Keyway cut on the lathe too.
Extension for a cheapo Forstner bit, I've a load of tubular latches to do and it was just a little too short to drill full depth.
Not machining but included none the less, cutting iron clamp from my Woden no4 smoothing plane, broken by some hamfisted moron (me), this was my grandfather's plane so I wanted to repair it. Has come out ok...looks like it may have a hairline stress crack already but I'll see how it lasts.
What filler metal did you use?
Worked better when I used a bit of release oil for cutting oil and it would actually cut and not just smear the aluminium.
