eLuSiVeMiTe
As above. Caravan hook ups are cheap enough.
Have a few of these kicking around.
Think I mentioned these earlier called fly leads ? But after countless research online I never heard anyone mention them being used on tig welding set ups. Thank you
They have nothing to do with tig so why would you.Think I mentioned these earlier called fly leads ? But after countless research online I never heard anyone mention them being used on tig welding set ups. Thank you
ok if your doing that on your own property but your hardly likely to get an electrician in to do it . unless he couldn't give a monkeys about it being wrong .13 amp is the max you can spur of a ring man at any one point
you will be fine with one of the above adaptors, if your welding a landy you wont be running the welder at full chat so the adaptor will cope no problem.
