How come you used duplex? Not familiar with F51, is that similar to 2205 duplex?It was yesterday but...
First job was to plasma cut out some sides for a roller from 12mm 5083
I then welded them to some flat so that I could pop into the Chiron to take the bore out to 1 1/4" and then decided to also take 1.5mm off the outside to clean it up.
View attachment 171265 View attachment 171266
Next was to make a pin from F51 Duplex, put it in the CNC lathe but things just went wrong with the CNC control, first it wouldn't jog so restarted, now it jogged but spindle wouldn't work, restarted and homing wouldn't work so safe to say the control has finally died and I will now start stripping it out in preparation for fitting the new control I have.
So back to old school methods using the manual lathe to make the pin, easy enough job but just takes a lot longer on the manual.
Pin is 150mm OAL, 1 1/4" main Dia and M20 thread.
Started on welding up the bracket, I would have been doing this while the CNC was making the pin but as mentioned that was not to be
Completed roller bracket, welding looks crap but it is actually not too bad or certainly not as bad as it looks in the pic.
Simply because I had some left over from making a prop shaft.How come you used duplex? Not familiar with F51, is that similar to 2205 duplex?
It looks like F51 is similar to EN 1.4462 which is the same as UNS S32205.Simply because I had some left over from making a prop shaft.
Not sure regards the 2205, it has always been F51 that I spec when the higher strength compared to 316 is required ie in highish powered boats which want the smallest dia shaft possible.
Noticing the status of the mandrels on those two Pop rivets, there appears to be a need for some clenching.
Yep, 1.4462 according to the delivery note.It looks like F51 is similar to EN 1.4462 which is the same as UNS S32205.
High strength and better corrosion resistance than 316SS in that case.
YeahPLA?
Could I have the file for them they look usefulBrackets to hold the sky Q mini box to the wall behind the tv.
Only took three goes to get them right.......![]()
Who supplied that? I think we’ve only got Aalco round here that do that sort of thing!
Mrs TYA likes it.
