Hood
- Carnoustie, Scotland
More clever than the operatorIve just watched your videos on how to operate said machine looks interesting ! very clever now arent they ?
Sometimes, but always looking to improveyou seem to know what your doing with it![]()
I have two EWM Phoenix Migs, the older 330 that I bought second hand and the 355 that I bought new. Both are excellent machines, the 355 being a wee bit better due to the ease of setting it up mainly. I haven't used the 330 since I gotthe 355 and I kind of feel sorry for it sitting lonely in the corner of the workshopreading your review , cant work out how I missed it ? I have EWM tig when I see EWM on the forum I read it but missed yours !
Not jealous or anything...Thanks but I think the CNC's should get most of the credit![]()
Don't need anything fancy really, I started way back with a Sterling 180 (I think) transformer Mig. It was a good duty cycle for a 180 if I recall.Not jealous or anything...
Would love to get into aluminium welding, But I'm too tight![]()
I do it myself although there is very little in the way of electronics other than connecting things together so basically just wiring and configuring.@Hood , on this cnc conversion do you get any help with the electronic wizardry or do you do the whole lot yourself?
Bob
Not sure if @8ob is talking about the software programming? But would be interested to know if it takes a genius to setup a cut program? Computers aren't my strong point eitherI do it myself although there is very little in the way of electronics other than connecting things together so basically just wiring and configuring.
The first retrofit I did was a manual Bridgeport and it was a bit of a mess, the next a CNC Bridgeport and I improved a bit as I was starting to realise how best to do things, the lathe was next and then I think I made a coil winder for a client and then the Chiron and lastly the plasma. Have also helped a friend do a few machines and every time I do one I improve as I see how to do things better.
This will be a bit different as it is more of an interface of a unit rather than connecting lots of different things up.
Not too sure what you mean, are you meaning to get a part coded so that the CNC will cut it?Not sure if @8ob is talking about the software programming? But would be interested to know if it takes a genius to setup a cut program? Computers aren't my strong point either
If so then it can be as easy as typing a line or two into the MDI line (manual Data Input) or if the part is more complex then some controls have conversational controls where you type in values and the code is produced. For more complex things you can use CAM and get the code that way.
Someone asked about that before, think @slim_boy_fat and I did a quick screengrab video to show how easy it was.
Here is an example of conversational
Here is a quick part for lathe from drawing to cam to code.
I enquired about Delcam once to go with a new cnc mill I was buying. This was in 2012 . The initial payment and a years subscription came to more than the brand new mill!!Not too sure what you mean, are you meaning to get a part coded so that the CNC will cut it?
Ha ha you are running out of room, now that is funny, you should try and work from my workshopI have to admit, that once you get your head around the software to get a drawing out to code for a machine to cut, then the job is quite easy. I don't do much drawing, I get the drawing files from the engineers as dxf's and process them from there. However since I have gotten my head around it much better it seem to be quite simple now, compared to before. The more you do the better you get and also the more you do, you improve the processes (feeds, speeds) knowing the capabilities of your machinery. Still, this takes time and the more toys you have the more you have to do and learn. My hat off to you @Hood for your capabilities. I still only have a plasma and am relieved to have that at my desposal, would I like to have more, YES, but there has to be a requirement for them, not to mention I am running out of space![]()
It is not cheap for CAD/CAMI
