mrsbruce
- Livingston, Scotland
guess it's more of an adventure when you're a kid tho
No, we were all just dafter.
No, we were all just dafter.![]()
How olds the silver solder? If it’s old it’s possible it’s got cadmium in itInteresting. I do a bit of mig welding but always outside. I do however do some silver soldering in the garage. I've had an irritating throat tickle for quite a while which has mysteriously disappeared together with a cough over Christmas as I went 'cold turkey' and haven't been doing anything in the garage. Could the silver soldering be the cause?
Cadmium is really really nasty. Highly carcinogenic.That'll be all of the stuff I have, then. Too old to worry about it now.
when i were a ladpah! you're all getting soft
when I was a kid I used to climb inside the galv drum of a big tripe washer and weld up the splits/cracks, crap mig gun in one had, hand held mask in the other and a hose pipe in my mouth to breath through
had to remember to breath in through the hose (mouth) and out through the nose.... easy to slip up and try to breath in/out through the hose - breath the same air in and out again
I have some silver solder rings that came from a munitions factory (second world war)How olds the silver solder? If it’s old it’s possible it’s got cadmium in it
Let us know if your testicles start growing abnormallyI have some silver solder rings that came from a munitions factory (second world war)
They were for soldering the ends on to brass cases
Be about 100 mm diameter
It flows very well
I will be using it outside from now on
...Then send me some
It is amazing how all the good stuff is bad for you
your right there JohnIt's very old. Came from the old Belling company in Enfield Middx. My old neighbor gave me masses of it over 35 years ago. Still using that and the flux.How olds the silver solder? If it’s old it’s possible it’s got cadmium in it
Be very careful with it. Make sure you’ve got a respirator and good ventilation. It kills you in a nasty nasty way.It's very old. Came from the old Belling company in Enfield Middx. My old neighbor gave me masses of it over 35 years ago. Still using that and the flux.
How long have I got?Be very careful with it. Make sure you’ve got a respirator and good ventilation. It kills you in a nasty nasty way.
It’s an accumulative thing or when exposed in large quantities usually.How long have I got?
I made it to New Year. So fingers crossedIt’s an accumulative thing or when exposed in large quantities usually.
Thanks for the warning though, I'm going to be careful from now on.No worries. Better later than never, I think about all the grinding dust and concrete dust I’ve inhaled over the years. Pretty worrying really but hopefully never an issue.I made it to New Year. So fingers crossedThanks for the warning though, I'm going to be careful from now on.
