brightspark
- yarm stockton on tees
my gas and water pipes been under the screed for 35 years just wrapped with duct tape. no problem
s
That's how I clocked we had an issue, the carpet and underlay did a great job of suppressing the water coming through, so it took to the walls![]()
I thought I was going mad looking for it. Assume you mean the kitchen cabinet with stuff on top?Is that a lathe in you kitchen @Rig Pig ?![]()
The copper is under the screed in our extension(in that brown fluff plastic backed insulation), Dad put it down in the early 80's my job after the screed was set was to pain white lines on the floor following along the runs, to prevent that very thing happening.Friends bought a new house and builder allowed carpet fitter access before the final exhange of contracts. On getting the keys friend found the house flooded - turned out buiders had burried central heating pipe in the screed and carpet fitter had put a nail into it when fitting the door strips !
I've heard a number of plumbers say that half the problem is with modern copper pipe. Wall thickness is greatly reduced and the quality of copper is not what it was. As a result, modern copper pipe is far more easily attacked by concrete.
That also depends on the purity of the copper. Impurities will be more easily attacked.Thicker pipe just means it takes longer for the reaction to eat all the way through, it doesn't make it harder for the cement to attack it.
copper pipe isn't that pure. nowhere near copper cable qualityThat also depends on the purity of the copper. Impurities will be more easily attacked.
Wrap the copper in Denso tape. Then line the channel with dpm. Screed over that, but use some cement dye to colour the infill. That way it will be easier to identify the pipe run.
If using 15mm copper, the Denso can be unrolled along the pipe length and moulded around the pipe. Definitely wear gloves!
So rather than messing around with Denso tape etc is the plastic coated pipe any good?
Exactly, just get some 16mm PEX-AL-PEX and throw it in there. Personally I'd plum an entire house in the stuff it is so much nicer to work with compared to regular pexWhat's your reluctance to use PEX, as I previously mentioned?
It's what they use in underfloor heating, so is tried and tested in the application.
Pex Al Pex! Now I'm confused! What's the difference between Pex & Pex Al Pex?Exactly, just get some 16mm PEX-AL-PEX and throw it in there. Personally I'd plum an entire house in the stuff it is so much nicer to work with compared to regular pex
