silicone breaks down with fuelSilicon would be fine I'd reckon and cheap.
and goes all squishy then try cleaning it out of your carburettors . been there and done itSilicon would be fine I'd reckon and cheap.
don't mention bison glue to meI would try a two part Bison polyurethane adhesive, its available in small size packs & will stick just about anything. I used some a couple of years ago to glue a plastic part subject to oil & vibration & it stuck like the proverbial to a blanket.
once glued the rubber manifolds to the metal flanges on the carburettors of my microlite supposedly the rubber to metal stuff. took off out of a field and got to 200 foot and the bloody carbs fell off
it was my 1st and last emergency landing in a corn field just missing a tree and a hedge
A guy in the club bought a car that had had the fuel sender sealed into the tank with silicone sealant - he removed it but would still have to spend the odd day removing "gorilla snot" from the fuel system for quite some time.silicone breaks down with fueland goes all squishy then try cleaning it out of your carburettors . been there and done it
don't mention bison glue to meonce glued the rubber manifolds to the metal flanges on the carburettors of my microlite supposedly the rubber to metal stuff. took off out of a field and got to 200 foot and the bloody carbs fell off
Try some hot melt glue - you would need to warm the spout up as well.
The spout not the can!Warm it using a blow torch for instant eyebrow removal.....
I use Wurth super RTV and it seems pretty good.ebay link,
292277732692
there on a rubber tube flanges either end bolted on to stop vibrationThat would put me off it i must admit, but surely carbys should have bolts as well?
