Adam Marshall
- Nottinghamshire England
What size three phase to single phase converter would I need for a 7.4kw output to power this motor? Also what type of converter is the best? Thank you
A solo vfd for a pillar drill is a plus for speed control. Suppose you could power tap with jog too?It looks like the motor can be wired to run on 220v x 3ph so you should be able to use an inverter, which are available on the bay of fleas.
The data plate states
415 volt......star
220/250....mesh(?)
Usually 3 phase motors are wired delta or star......unless mesh is another term for delta, you'll have to wait for one of the sparkles to confirm...
I managed to rewire mine no issue. Wasn't rocket science. Just moving a few jumpers around. Same for vfd. Easy enough.Is there not just a converter I can plug it into?
Yes. Cost a damn sight more than a small vfd...Is there not just a converter I can plug it into?
Just beat me to it.Yes,,,,,BUT a 415 volt converter will cost more than a 220v x 3ph inverter, plus a converter will be a single speed, where an inverter will allow variable speed.
YesIs there not just a converter I can plug it into?
