doubleboost
- Newcastle upon Tyne England
I dont see why not.If you ran one of these from it's own little fuel tank, would you be ok using red diesel with a vehicle?
If it isn’t, chuck it my way, it might heat the truck cab on my defenderBanggood are a import company.
I have done a few video reviews for them.
I get to keep the items i review & get a small commission.
It will never make me rich but it all helps
The items i have reviewed have been mostly metal cutting tools
In sort i get the heater for "nowt"
Saying that if it is no good i will say just that no holds barred at all
My Touareg has a webasto built in, Purely for helping the engine to heat the coolant when the temp drops below 4* According To VW, the engine is "so efficient" it doesn't put a lot of waste heat into the water, so in the winter needs the webasto to help to heat the water more quickly.. Driver has not got any control over the system at all and there is no indication that it is working. If anybody has any further info, I would be very interested,
It is starting to get a bit cold in the shop.
.It is not for me it is the machines that feel the cold lolThought you were a Gerordie?![]()
From what i gather they will burn anything .
I get a fair bit of diesel petrol mix at work.
From people putting the wrong fuel in to vehicles.
We used to run the jet kart on it.
when i worked in Norway we had them in the
transit crewbus set the timer and all the snow was melted and toasty warm to get in to , block heated too so start at -25 easy why dont we get this option
What brand was this heaterI got a 5kw one off ebay last year. Unfortunately it seems to have been a return, as one of the wiring blocks was damaged. After setting up, I had a multitude of problems caused by really carp connectors, including the glow plug giving up.
Did a big complain to seller, and got a hefty lump of my money back. Bought a bundle if cheap aftermarket spares (new board, glowplugs, and pump), and heater seems fine now, and although only used in a test situation, does give out a nice bit of heat.
I put it aside for a bit, but need to get it set up in place, to feed heat into both huts now.
They are quoting 0.2 litre per hour
Running on red or kerro should be OK
Be better than the electric fan hearer i have now.
At least you can see how much you are using
