addjunkie
- Northumberland. Reet oot in the sticks
The last DRO I had on my old machine, had a memory, so If you had 10 holders, you could set up to remember tool 1 has an offset of say 5 mm, tool 2 etc,
So when you change holders, you select which holder your using and in theory it cuts the diameter shown on the dro. Unless like I did, you change the tool but not the offset, so I thought I was machining to a nice h7 g6 fit or what ever, and it was 2 mm out, the wrong way, off to the scrap bin it went.
Some call it zero memory. Basically its supposed to save you checking the diameter and setting the zero each time.
going to research whilst on holiday i may well take the plunge and do it as i put it back together
