Winter barley I assume did it come off ok ??
lol.
cmon then what moisture and what weight? poor crops allways ripen faster,lol.
Anything ripens faster in this weather lol we have spring barley at work just turning but desperately in need of rain to fill the grains out
EVERYTHING is needing rain right about now!
We've had to abandon the idea of taking a second cut from our silage ground![]()
They are also too short having been cut and welded so were hitting the chassis. Stainless pipes with mild flanges.Do you mean Slurry (cow manure) as silage is just grass, albeit a bit smelly when it's off or well fermented!
Nice workTo cut a long story short all I could say was Foxtrot Foxtrot Sierra when I went to replace a pair of blowing downpipe gaskets last week, found these as downpipe to cast iron manifold flanges.
View attachment 147529 View attachment 147530
With heatproof Aluminium paint the downpipes look new to the untrained eye and were recently fitted.They are also too short having been cut and welded so were hitting the chassis. Stainless pipes with mild flanges.
Temptation was to plasma cut a pair and Mig them to the existing flanges, kind of what I ended up doing.
Plasma cut some scrap and flap wheeled the dross off, impressed they’re both within 0.5mm by eye!
Tack all the corners together, mark and drill the bolt holes then centre on a faceplate in the lathe. Hog the centre to 48mm with a holesaw.
Bore to 57mm.
Rasher down to shape on the mill using MkI eyeball and scribe lines.
Fettle on linisher to shape.
Tig braze to original pos fanimold flanges.
The calibre of bolt cutting exceeds the parts supply!
He called it silage and it was steaming from memory, covered it tarps and old tyres.
Yes that's silage. Might have been wholecrop (chopped up maize) as it really does stink. Silage is only bad really when it's a wet crop. Love how I've been modded, though manure is more polite than my s word with a 1 in it it's not correct, Slurry is liquid, usually a min of poo and wee and rain water from the dirty yards, which is spread once mixed onto the land as fertiliser, manure is usually a mix of the above minus the water but added to start used in dry bedding in a barn. Which is left to rot for a year or so, then spread as fertiliser. I know of no farm that piles poo up as a solid.
