that don't kill roots then otherwise you couldn't eat the spuds
True, but if you keep hitting it with it could work. Apparently if it is repeatedly cut down it eventually dies.
Have you tried Gramoxone, farmers used to use it on potato crops before machine harvesting to kill the vegetation.
My argument is that while obviously some pest/weed control may be necessary in certain cases it has become the easy option to chuck chemical poison at every such problem. Pouring boiling water on most garden weeds a couple of times will sort most out.
What about the knock on effects of removing the early pollen and food sources of important pollinators and birds?
It all impacts on biodiversity.
https://intpolicydigest.org/2017/09/14/what-you-need-to-know-about-the-monsanto-roundup-controversy/
https://www.independent.co.uk/news/...nger-agriculture-partial-report-a7522391.html
Think so..Are you for real?.![]()
Think you're going to need a bigger kettle.I hardly think boiling water is going to do anything for my gravel drive and round my field - garden you could get 20 cars on it and get all the crap weeds up the railway embankment coming in
sheep are better goats jump the fencepersonally i would go out an buy 2 goats, problem solved.
How can you have biodiversity if Bindweed is choking everything else in your garden ?What about the knock on effects of removing the early pollen and food sources of important pollinators and birds?
If its choking your garden then you've let it .How can you have biodiversity if Bindweed is choking everything else in your garden ?
beats petroleum and swan vestas.Oh dear, if you don't like Glyphosate, you really wont like my special mix of diesel and used engine oil, I call it my scorched earth potion.
Joking of course! never know when SEPA are watching....
