Whats a kerfmaker?Kerfmaker printed out:
List price is around $73, so I reckon the Anet has paid for itself, already.
It will be transfer tape. It adheres to the vinyl and lifts it off but when placed on a surface and then lifted of leaves the vinyl in place.4" wide masking tape of some type.
Came with the machine - seller was a vinyl sign maker, and it's something he used for that.
I could find out - I have a piece of glass on order, so wasn't overly bothered about it, tbh.
See above...The masking tape is definitely NOT factory original.
Seller applied it from a big roll whilst I was there.
It's an adjustable stop block type thing for cutting accurate grooves on a table saw, without a dado blade.Whats a kerfmaker?
Ah i thought it was a kids toy. LolIt's an adjustable stop block type thing for cutting accurate grooves on a table saw, without a dado blade.
YesAh i thought it was a kids toy. Lol
Is it on thingyverse ?
just print the boltsYes
https://www.thingiverse.com/thing:1345031
If you decide to make one, consider changing the bolt sizes to M5.
M4 hex head screws/bolts are a pita to get hold of, locally - I had a choice of a 10 mile round trip or the bay.
My local ironmongers (geo Spence) don't stock them, not does Screwfix or Toolstation, or been n queued.
M
Scooe creep there - this cheap printer is getting expensiveOrdered some abs filament, and going to make a perspex cabinet with a rollout shelf for the printer.
Scooe creep there - this cheap printer is getting expensive![]()
View attachment 145070 drill stop for 8mm "joint genie" dowel jig.
To replace the (quite frankly, rubbish) included depth stop.
Things I learnt today:
STL files are unitless.
I default to inches in fusion.
Cura uses mm as default.
So models have to be scaled up by 2540%
Yes.You can change the standard units in fusion 360
ALSO
If you are in mm in fusion and you put in a dimension and write " 2.0 inches " it will convert it into mm
I got mine off farcebutt on a local selling group.Where are folk buying these printers from?
As i fancy one but i have heard that some of the really cheap deals are actually a cheap knockoff
