bigegg
- Leeds, West Yorkshire
That's what she said...It’s more about how it’s hung I think.
Thats Arthur the boss.Who is the old guy?![]()
Picked these up to give me something to do today.. The record autovice looks ok and the other is just called a record 47 but looks pretty much the same..
I had the base.
The pipe jaws and anvil bit were missing but i have another autovice so i can make a cope of the jaws, I have not seen the anvil bit bit i pressume it goes into the hole on the top.The record auto vice is nice, it’s cast steel and the little holes on the side are for holding valve stems. It should have a little removable anvil on the top. I have the same but the base is missing
But you got a present.
A 16A supply in the workshop so I can use the welder to, hopefully, its full potential. Project Management, as I affectionately refer to her, insisted that we get a qualified electrician in; I could have done it myself but better to be safe. He'd fitted a plug to the Parweld too, not that I anticipated that at all, and I'd bought one at Screwfix on the way home... lucky I had as he'd fitted a bigger 32A plug! I'll let him know and check it isn't on the invoice...
Oh, if anyone can make use of the old Wylex NHRS204/63 consumer unit let me know and you can have it for postage and a pint - has a Wylex 63A/30mA WRS63/2 RCD installed.
Do you need to use a specific plug for the socket to lock it in??
Yup - the 16A one. The 32A he'd fitted is physically larger, much larger diameter! He was a bit embarrassed when I emailed to let him know that he can swing by and pick up the 32A he'd fitted!
I've got a similar one in 32a any plug works you can't switch them on without a plug in and you can't remove the plug whilst its switched onWhat I mean is will it lock any 16A plug in or do they need to be the same make as the socket?
