rtcosic
- Warwickshire
lol forum fee is if you want to subscribe to it but ya dont have to do it
No, no. Henry is correct, I was lightheartedly referring to the need for photographs, not donations.
When you get a water trap Sandra, you want one with a pressure regulator on it, otherwise you will need a separate one. Get yourself some PCL quick release air line couplings as well to make life easy for yourself, if you look in the Screwfix catalogue on line, or Machine Mart, they are in there & some hose to 1/4 BSP to connect the hose the couplings. Have a look, it's fairly straight forward. If you need any help as to which ones, just ask us.
I watched the unboxing video couple nights ago I funny that he was connecting the hose to the wrong inlet, funny in that I will be exactly the same haha I will have the gun, the compressor, the hose, the couplings, the water/oil trap but how any of this connects together will be another conundrum for me to figure out haha hoping there will be some simple how to set up your compressor step by step for dummies videos for me to look at hayou should try it when you buy a plasma cutter then find out you need the expensive air compressor as well
as i found out and so does many people out there
and I’ve no idea what a plasma cutter is or does
But if she bought one, she could cut out her own steel, then make her own furniture....but of course she would then need to start again with " what welder do I need"That's a whole other learning curve, but you don't need to concern yourself with one of those [yet]. Little steps for starting out......
You don't need to worry, it won't work on wood![QUOTE="Sandra bellew, post: 1168805, member: 31856] and I’ve no idea what a plasma cutter is or does
And then setting the psi etc jeez should I have just stuck to my paint brush and I’ve no idea what a plasma cutter is or does
I think you will find the best thing is to play about with it on some scrap wood & see what works for you, I've never tried spraying water based furniture paints, & I would guess not many on here have, but a bit of trial & error & I don't think you will find it too tricky. If I was going to try it, I would start with several thin coats, as I would think it had a tendency to run as it wouldn't have the viscosity of an oil based paint. I could be completely wrong (& generally are) as I am no paint sprayer, just dabbled with odd bits
