hotponyshoes
- Somerset. Uk
I would like to make a bar top / kitchen worktop from copper.
I don't want to end up with the 'hammered finish look but rather a brushed finish so to avoid the dents I am looking to use 3mm+ thickness. This is obviously ridiculously expensive and very heavy.
On the up side, there are joints that need welding so that would be easier on thicker stock.
To reduce the cost I am thinking that if the copper could be bonded tightly to a backup of cheaper material (e.g. steel) it would have the same dent resistance as a thicker sheet of copper at a much lower cost.
I have tested a few small samples and they are far too noisy to use when putting things down on them. The worktop also needs to be fixed down somehow, and not sag/deflect when a person sits on it etc.
Builder mates are saying 1" thick sheet of mdf and paint it with pva to make it water resistant. Or 3/4" marine ply and not treat it at all.
They also say stick the copper directly to the mdf with silicone. (This is not really an option as I think it's going to be easier to fit it all into place and weld up last)
I know most standard kitchen worktops are plastic coated chipboard and they hold up fine so I suppose I could just use loft type flooring or something or even cheap kitchen worktop but I can't help thinking it should be a bit better quality than that?
