Slightly low it was. Packed to height with a 12mm tool blank and one leaf of a butt hinge.Yes, dead on centre, or sometimes fractionally above for blade type, is required. Well fractionally below it would be in your case![]()
il make a one piece spacer for it sometime.
)Someone tried hard on my rear tool post. Can see the repair on it on the above photo.The cutting force is tending to lift the cutter. When parting off using the conventional position it's not uncommon for the tool tip to dig in and get dragged under the workpiece, breaking the tool and damaging the piece. With a rear mounted post the force is liftiing the cutting edge so considerably reduces damage due to dig in (that's not to say you can't break the tool, you just need to try harder)
Surely when it is upside down then the same can happen on the rear, ie it lifts and can get dragged in. Main benefit to my mind is gravity clears the chips.
So out of interest chaps. What are the benifts of using a rear mount tool post over the conventional tool post.
Thanks Pete.I once saw an animation that explained it very well. Basically when the blade is overloaded and forced downward it putting a tremendous amount of spring into the sliding assemblies by compressing all the moving joints together between the work and the lathe bed. Eventually the pressure becomes so great that the tool is forced upwards sharply then the cycle repeats which is how you get parting chatter. Using the rear tool post and the tool upside down does 2 things - it removes 3 flexible elements (the tool post, the compound slide mount and the compound slide dovetail) making the tool post more rigid and less likely to dig in plus instead of forcing everything down in towards the bed it tends to put some lift on the carriage and cross slide which is - for want of a better term - a much less harsh action. It's still a lot of force imparted to lift the saddle and apron off the ways but it's not inducing huge spring forces in the assembly.
Original bracket is in two pieces and I don't have the second piece Unfortunately.It doesn't look like the tumbler teeth match the change gear teeth. Can you post up OD and tooth count for those because they look like they are different DP.
Why can't you use the original tumbler?
Yup. Would have given 200. Taken what I needed faceplate chabgewheels tailstock etc and sold the rest on for a reasonable price to recoup my money.That's a piece of scrap or a boat anchor..
