Richard.
- Cambridgeshire
No rush mate. Do the other guys first. Happy to hang on at the back of que.Working on it mate - little steps....
looks great by the way.
Look forward to hearing the results when you test the first.Boards have arrived folks, kit them up and get them soldered then It's press on with the front panel design and get those made.
It's node.js indeed... #dayjobIs that node.js onscreen Hugh?
Edit - looks like typescript?
Building an embedded control system for a mechatronic device using a beaglebone black and a chunk of node.js and Pru code
No mate you weren’t.I am I the only one that couldn't make any sense of this?
And I have a history in IT too.
I did it by hand with a little 10cc syringe pump. If I was doing more then I'd invest in one of these:Did you get a solder mask with them as well Hugh or just do it by hand as there's only a few?
Don’t leave us in suspense Hugh.
I didn't have any of the mating connectors for the 10 way connection back to the machineDon’t leave us in suspense Hugh.
I’m dying to know if it works or not.
will probably be next week now before I can take delivery of those... the front panel design is an hour or two away from completion though. Does this look any good?
It looks awesome Hugh.I didn't have any of the mating connectors for the 10 way connection back to the machinewill probably be next week now before I can take delivery of those... the front panel design is an hour or two away from completion though. Does this look any good?
@Richard. the plan is to make a batch of 10 panels to this size and shape (the MOQ from the panel maker) but without the corners cut off. Everything else will be the same so it will fit your case. I'll leave you to trim the corners off with a saw and file them smooth. Does that sound like a plan? I can then use the others for normal sized cases (hopefully)
Looks the part.I have finished the frontpanel design and sent the files off for quotingThis has been a lot of fun figuring out the intricacies of the PCB software for doing artwork on the silkscreen layer
Absolutely mate...Looks the part.
When you get round to mine mate can you send the old panel I gave you back with it so I have a template to cut the corners too.
